Currently the mudfish is not running
Hello, I’ve been trying to connect/switch on mudfish but it says
“Currently the mudfish is not running.” and doesn’t allow me to switch mudfish on for use
At the bottom there is no option to switch it on. I ran it as administrator a couple of times to and it does not work.Can you help me with this?
My data still has load and mudfish used to work last week. I did not change any settings. Just suddenly mudfish does not want to work. I have tried reinstalling and still no fix. There are no errors in the log
Did you check ‘Status → Process’ menu to see “Core” log section? Please check if there’s an error or warning message there.
However which mudfish version are you using? Are you using the latest stable version of Mudfish?
the core show the problem here but i dont know how to fix it :frowning:
[2.431927] [INFO] TAP-Win32 Driver TcpNoDelay diabled
[2.431927] [INFO] TAP-Win32 Driver TcpAckFrequency 1
[2.431927] [INFO] TAP-Win32 Driver TCPNoDelay 1
[2.444023] [INFO] Uses the macaddr for msk(4) (cached).
[2.451048] [INFO] Ready
[2.462720] [INFO] Waiting until the client’s ready to handle the routing path list.
[2.465034] [INFO] DHCP request for 00:ff:cd:99:2d:86 (MSI) from interface
[2.486196] [INFO] DHCP discover for 00:ff:cd:99:2d:86 (MSI) from interface
[2.489302] [INFO] DHCP request for 00:ff:cd:99:2d:86 (MSI) from interface
[2.490302] [INFO] DHCP Client got IPv4 address now
[2.561016] [INFO] Listening the management console at 127.0.0.1:61260
[3.573215] [INFO] Delete default gateway for Tap-Win32 adapter.
[5.471478] [INFO] MFP RouteAdd - 107.20.0.0 255.252.0.0 121 3 0 n -1 0
[5.471478] [INFO] Fetching new static node SID 121…
[5.905176] [INFO] 18.166.77.234 is registered in the routing monitor: 1
[5.905176] [INFO] re110: Broker feature is enabled. (maxconns 3)
[5.906176] [INFO] re110: Connected to 18.166.77.234:10008 (UDP)
[5.907171] [INFO] MFP RouteAdd - 119.147.6.0 255.255.255.0 121 3 0 n -1 0
[5.907171] [INFO] MFP RouteAdd - 119.28.0.0 255.254.0.0 121 3 0 n -1 0
[5.908186] [INFO] MFP RouteAdd - 129.226.0.0 255.255.0.0 121 3 0 n -1 0
[5.908186] [INFO] MFP RouteAdd - 13.112.0.0 255.252.0.0 121 3 0 n -1 0
[5.908186] [INFO] MFP RouteAdd - 13.124.0.0 255.252.0.0 121 3 0 n -1 0
[5.908186] [INFO] MFP RouteAdd - 13.228.0.0 255.252.0.0 121 3 0 n -1 0
[5.909191] [INFO] MFP RouteAdd - 13.232.0.0 255.248.0.0 121 3 0 n -1 0
[5.909191] [INFO] MFP RouteAdd - 13.24.0.0 255.248.0.0 121 3 0 n -1 0
[5.909191] [INFO] MFP RouteAdd - 13.248.0.0 255.252.0.0 121 3 0 n -1 0
[5.909191] [INFO] MFP RouteAdd - 13.32.0.0 255.240.0.0 121 3 0 n -1 0
[5.909191] [INFO] MFP RouteAdd - 13.48.0.0 255.248.0.0 121 3 0 n -1 0
[5.910182] [INFO] MFP RouteAdd - 13.56.0.0 255.252.0.0 121 3 0 n -1 0
[5.910182] [INFO] MFP RouteAdd - 149.202.0.0 255.255.0.0 121 3 0 n -1 0
[5.910182] [INFO] MFP RouteAdd - 162.14.0.0 255.255.0.0 121 3 0 n -1 0
[5.910182] [INFO] MFP RouteAdd - 18.128.0.0 255.128.0.0 121 3 0 n -1 0
[5.910182] [INFO] MFP RouteAdd - 18.32.0.0 255.224.0.0 121 3 0 n -1 0
[5.911181] [INFO] MFP RouteAdd - 18.64.0.0 255.192.0.0 121 3 0 n -1 0
[5.911181] [INFO] MFP RouteAdd - 205.251.192.0 255.255.192.0 121 3 0 n -1 0
[5.911181] [INFO] MFP RouteAdd - 206.127.144.0 255.255.240.0 121 3 0 n -1 0
[5.911181] [INFO] MFP RouteAdd - 216.137.32.0 255.255.224.0 121 3 0 n -1 0
[5.912182] [INFO] MFP RouteAdd - 218.76.64.0 255.255.224.0 121 3 0 n -1 0
[5.912182] [INFO] MFP RouteAdd - 223.240.0.0 255.248.0.0 121 3 0 n -1 0
[5.912182] [INFO] MFP RouteAdd - 3.0.0.0 255.128.0.0 121 3 0 n -1 0
[5.912182] [INFO] MFP RouteAdd - 3.128.0.0 255.128.0.0 121 3 0 n -1 0
[5.913291] [INFO] MFP RouteAdd - 34.192.0.0 255.192.0.0 121 3 0 n -1 0
[5.913291] [INFO] MFP RouteAdd - 35.152.0.0 255.248.0.0 121 3 0 n -1 0
[5.913291] [INFO] MFP RouteAdd - 35.160.0.0 255.240.0.0 121 3 0 n -1 0
[5.913291] [INFO] MFP RouteAdd - 35.176.0.0 255.248.0.0 121 3 0 n -1 0
[5.913291] [INFO] MFP RouteAdd - 44.192.0.0 255.192.0.0 121 3 0 n -1 0
[5.913291] [INFO] MFP RouteAdd - 50.16.0.0 255.252.0.0 121 3 0 n -1 0
[5.914637] [INFO] MFP RouteAdd - 52.0.0.0 255.192.0.0 121 3 0 n -1 0
[5.914637] [INFO] MFP RouteAdd - 52.192.0.0 255.224.0.0 121 3 0 n -1 0
[5.914637] [INFO] MFP RouteAdd - 52.64.0.0 255.240.0.0 121 3 0 n -1 0
[5.914637] [INFO] MFP RouteAdd - 52.84.0.0 255.252.0.0 121 3 0 n -1 0
[5.914637] [INFO] MFP RouteAdd - 52.88.0.0 255.248.0.0 121 3 0 n -1 0
[5.915756] [INFO] MFP RouteAdd - 54.144.0.0 255.240.0.0 121 3 0 n -1 0
[5.915756] [INFO] MFP RouteAdd - 54.160.0.0 255.240.0.0 121 3 0 n -1 0
[5.915756] [INFO] MFP RouteAdd - 54.176.0.0 255.240.0.0 121 3 0 n -1 0
[5.915756] [INFO] MFP RouteAdd - 54.192.0.0 255.240.0.0 121 3 0 n -1 0
[5.916775] [INFO] MFP RouteAdd - 54.208.0.0 255.248.0.0 121 3 0 n -1 0
[5.916775] [INFO] MFP RouteAdd - 54.216.0.0 255.252.0.0 121 3 0 n -1 0
[5.916775] [INFO] MFP RouteAdd - 54.220.0.0 255.254.0.0 121 3 0 n -1 0
[5.916775] [INFO] MFP RouteAdd - 54.224.0.0 255.240.0.0 121 3 0 n -1 0
[5.916775] [INFO] MFP RouteAdd - 54.240.0.0 255.240.0.0 121 3 0 n -1 0
[5.917774] [INFO] MFP RouteAdd - 54.64.0.0 255.224.0.0 121 3 0 n -1 0
[5.917774] [INFO] MFP RouteAdd - 64.25.32.0 255.255.240.0 121 3 0 n -1 0
[5.917774] [INFO] MFP RouteAdd - 67.202.41.0 255.255.255.0 121 3 0 n -1 0
[5.918768] [INFO] MFP RouteAdd - 52.44.221.0 255.255.255.0 121 3 0 n -1 0
[12.962215] [INFO] MFP FlowMTU - 14.63.214.216 1280
[12.962215] [INFO] MUDEC_00179: Path MTU is wrong. (1280/1400)
[20.617526] [INFO] Shutting down.
[STDERR]
Empty file.
@tzianhao Thank you for this log. When I checked this log properly, all logs are INFO-level messages. So no warning / error level messages are here.
Could you please confirm that How to check the basic functionality works fine too? If it’s even same with Full VPN mode enables, please send us Problem Report.
