Custom WFP item Escape from Tarkov works but still disconnects every 3-4 minutes
I recently created a WFP item for Escape from Tarkov since the one that came with Mudfish does not work most of the time. It works but however, every 3-4 minutes or so, the game will say “Server connection lost”. I have tried many different nodes, tried TCP instead of UDP, and it was the same behavior. What do I do?
Below is the routing path of my custom item
  • P:BsgLauncher.exe
  • P:BsgLauncher
  • P:backgroundTask
  • P:EscapeFromTarkov_BE.exe
  • P:BEService.exe
  • P:BEService
  • P:EscapeFromTarkov.exe
  • P:UnityCrashHandler64.exe
  • P:svchost.exe
  • P:WmiPrvSE.exe
  • P:WmiPrvSE
I’d left my answer on another topic you created on the Private Support menu. Please check it there. :slight_smile: You can find your topics at https://mudfish.net/forums/iwrote link.
