Data Plan Suddenly went minus
Hello, my data plan suddenly went into minus, I don’t understand what happened? Was having like 20+gb an hour ago. I’m pretty sure no game will use 20gb+ of data in an hour. Playing Warmane btw. Is there any way I can check my data usage? Or does something wrong? Thank you.
Please visit ‘Account → Edit profile’ menu to enable the Connection Log feature to see where your traffics were used. You can find it at https://mudfish.net/admin/user/modify link.
For your convenience, I’d reset your mudfish credits a little bit.
wow thank you very much! 10/10 customer service! Alright I’ll check them out, again thank you! :smiley:
