I used mudfish with ppt plan for playing wow. I would like to know one thing. Which one is better for gaming?
Default node mode or full vpn mode. I used default node mode and the result is satisfying with the correct setting.
For latency or ping, default node mode gives better than full vpn mode or full vpn mode gives better than default node mode?
For full vpn mode, i know there will be change in location, which can sometimes lock the game account.
If full vpn mode is better, I am going to use subscription plan.
Btw, thank you for giving us, cheap and good service.
In a view of ping, there’s no any difference between default node mode or full vpn mode. That’s all.
Please check Full VPN mode for details. If the default node mode works fine, you don’t need to use this mode at all because it causes unexpected latency when the box is under heavy traffic loads.
