Delta Force connection issues
As shown in the image below, I am playing the international version of Delta Force. Regardless of whether I select a Japanese or Singaporean server in Mudfish, I am detected as being in a region not permitted for the international version, which prevents me from entering the game. Please tell me what’s wrong?
I’ve tried other global proxy VPNs and they can successfully enter the game, but the latency is unstable.
If it works fine with Full VPN mode enabled, it means there’s something a problem in the game item of Mudfish. For that case, I need to collect some game packets using Packet Capture with Mudfish.
Full VPN mode allows Delta Force to run normally.
Delta Force packet
Download the packet dump file
Full VPN mode: Yes
I’d left my answer on the packet dump topic you uploaded at Private Support menu. Please check it there. :slight_smile: You can find your topics at https://mudfish.net/forums/iwrote link.
