Hi, I am now in Perth, and when using Mudfish for Dota 2, the game is unable to calculate server ping. And without server ping, I cannot queue for games…
Does anyone have the same problem? When I was in Queensland it was fine…
I use Singapore node for the game, pay by traffic, etc.
On Full VNP mode, Ping: Failed error from Dota 2, which is even more serious.
I connected through the Perth RansomIT4 node. I also reset all settings, default everything.
Umm… Did you check How to check the basic functionality too while you tested it with Full VPN mode? I’m not sure that Mudfish worked fine at that moment.
Full VPN it works fine according to your information. How do I check if something is wrong with the game item?
If I followed your comments properly, it seems your machine is
Am I correct? Because you’re using with Full VPN mode enabled, your issue might be not related to the game item in my opinion. Did you try to change a mudfish node another?
