ei i need your help. i just bought Mudfish so that i can play WOW - Warmane server. my normal latency was 312ms, now it’s 575ms. i don’t know how to solve this
i am running in basic mode. i have chosen the best node. now it is running at 254ms. if you compare to WTFast, it is way to far. how can we solve this?
Umm… Then did you try to enable “Include the result for the advanced mode” option found in ‘Setup -> Nodes’ menu and check the recommended pathes? I’m not sure using the advanced mode would be helpful for this case.
Hello thanks for this advance mode. my next question is…
The yellow marked is working okay… like scale of 8/10… but when i try the circled blue, it doesn’t work. it says high latency. can you please help on that? i would be happy to play less than 200ms.
Umm…
Please let me check Mudfish side first because when I checked this result, it seems it’s less trustworthy…
yes please. please let me know your findings as soon as possible. thank you in advance.
what is the latest on your test?
i have not received any updates from you. can you please reply on my pending case?
Sorry for this belated response. When I checked above circled nodes, it’s a fault of mudfish daemon to calculate RTT information.
‘CH Europe (Zurich)’ node has a DDoS appliance in front of the node but it seems it makes the result wrong for this case…
