When i try to use mudfish on linux it shows lots of error while on windows it is okay.
i already try all solution and it still not work.
when i try using mudrun -I it has no error but it does not connect to server
using vpn mode work and can connect but i dont want to use full vpn
Which Linux distribution are you using? For this case, please check MUDEC_00002.
If possible, please show me the output of netstat -nr
command while this issue happens. I guess that it’ll be more related to the routing issue.
