I am attempting to connect from Melbourne, Australia to the Khabarovsk server.
Using multipath it normally selects the Sydney Amazon EC2 entry node and an exit node in Tokyo, Japan, reducing my ping from 430-450 down to 140-150, however since the EFT 12.12.30 patch I’m no longer able to route traffic.
The launcher will reduce to ~150ms fine so I can select Khabarovsk, but once I join a raid the ping will be at 450ms.
I have attempted to do full VPN and packet dump, but the file ends up being 100mB after a 30 second run through on a raid and fails the upload.
Are you sure that it works fine with Full VPN mode? I’m not sure that this issue is from the mudfish game item.
If it doesn’t work to upload the packet dump, please check Packet Capture with Mudfish link and send it to us via email. You can find it at the link and let us know after sending it.
I jumped on tonight to test some more. I have not changed anything and it seems to be working again!
I’m guessing it must have been an undersea cable issue.
It works for a couple of games and then all of a sudden I no longer see traffic via the item anymore.
I’ve tried disconnecting and reconnecting, no luck.
I’d left my answer on the packet dump topic you uploaded at Private Support menu. Please check it there. You can find your topics at https://mudfish.net/forums/iwrote link.
Hi there, thank you for your assistance. I was able to get a high ping server again and connect using full VPN mode. The packet capture can be found here;
