I mostly use Mudfish for Bless Unleashed lately and it working fine.
But there’s some problem I thought it wouldn’t be a problem at first so I ignore it but now it’s back and I thought it’s time to report
take a look on this Pic
It’s have an obvious excessive usage and I’m pretty sure I didn’t turn on the full connected mode
I tried to look on my Access Log and here it is the second Pic.
there’s also an obvious excessive usage, how can one game can use that much Data while I mostly running around and doing normal stuff.
the graph on first Pic prove that on last month (July) I use Mudfish to play FFXIV and it doesn’t use that much
This month (August) I focus solely on Bless Unleashed, I notice a different amount of Data usage but I thought it would be different from game to game so I didn’t look to it too much.
But there’s one day on August where this problem happen for the first time, I open Mudfish > Looking for a Node to use > Connect > then go AFK doing my RL stuff and when I came back the screen show tons of Error message, I panic and disconnect Mudfish but it was a little too late, Data was use for a good chunk.
I thought that was my fault so I topup for more Balance and went on with normal gaming session.
And then it happen again, today
As you can see it took WAY TOO MUCH data for some reason.
I’m not an expert so I might need some suggestion or a guide on this is a problem on my side or it is something wrong happen to the Node or Game I played with
Thanks alot
