Hello. I have been getting the same error for the past few days and I’ve searched for a solution but was unable to find any. Even this site (https://docs.mudfish.net/en/docs/mudfish-troubleshooting/errorcodes/) did not show how to solve it. The error ir the following: [212.76] MUDEC_00539: Checking RTT to mudfish nodes are failing. Are you under network firewall? (c 16)
If you can see that the basic functionality works fine but still you see MUDEC_00539, Please try to change ‘RTT Checking Method’ found at ‘Setup -> Program’ menu.
