First of, the program works great for me so thank you and keep up the good work! I just have some question, which are:
- Each time I start or reconfigure mudfish that requires a restart, I keep getting the prompt from Windows of a new network. And the network number persists and keeps on incrementing even after PC restart. (Screenshot, up to Network 8 now) Any way to prevent it? The increment and/or constant prompt of new network.
- Why is command prompt also affected by mudfish when I run a tracert even if I have full VPN mode off and only equipped 1 item? I thought that only the equipped item/program would be routed thru mudfish. Don't need to know the technical details of it, just wondering if that is intentional.
