For some reason. it keeps sayi
For some reason. it keeps saying that i dont have a configuration. i dont know what is wrong with it though everything looks to be in order. the only thing i saw was next to the node it still has the looking glass and not a checkmark
Could you please elaboarate where you can find a messge regarding to “dont have a configuration”.  Is it from Windows, Mudfish, Game client?  If you’re first to use Mudfish, please check Quckstart link and try to check whetherh the basic functionality of Mudfish is fine.
I got help from a friend and we managed to fix it. everything is good now
Ok also im not very good at this type of thing but here is basicly want i want from this. I want to be able to play Revelation Online with around 270ms (lower then that probably gets expensive) so how much per month would that be?
Also i went from .03 to to having no money. without Mudfish even being turned on. so i dont know what happened there
Because your current data plan is subscription, I don’t think you’re now able to use Mudfish for that game due to no item equipped.  However at this data plan, it’s 990 KRW (Korean Won) per a item.
Please check Why my traffic get wasted while i am sleeping? section first.  I think you already consumed all traffics when your data plan was pay-per-traffic.
http://mudfish.net/docs/en/vpn/errorcodes.html#mudec-00179
http://mudfish.net/docs/en/vpn/errorcodes.html#mudec-00126 check these
Thank you for sending this problem report. :slight_smile: However is there any problem to use Mudfish? If then please elaborate little bit more for me.
유럽처럼 멀리 떨어져 있는 곳은 RTT를 낮출 수 있는 한계가 있습니다.
핑
방법이 없을까요? 한칸 올려주는 중계서버도 지금 찾은게 하나입니다.
RU Europe (Novosibirsk - JSC)
RTT 자체를 낮추는 것이 어려운 경우 연결 프로토콜을 변경하거나 FastConnect 모드를 사용해 보거나 MTU 값을 1450보다 낮춰보는 방법을 시도해 볼 수 있지만 큰 효과를 보지 못 할 수 있습니다.
