Fresh router with openwrt
hi guys! I just got a new ac1750 from TP link and was able to install 19.7.3 on it. Im new to these things and is very unfamiliar with Openwrt.
I was able to install the packages but when i click on services >> mudfish, i get this error. I hope you can help me. Thank you
/usr/lib/lua/luci/dispatcher.lua:1329: module ‘luci.cbi’ not found:
no field package.preload[‘luci.cbi’]
no file ‘./luci/cbi.lua’
no file ‘/usr/share/lua/luci/cbi.lua’
no file ‘/usr/share/lua/luci/cbi/init.lua’
no file ‘/usr/lib/lua/luci/cbi.lua’
no file ‘/usr/lib/lua/luci/cbi/init.lua’
no file ‘./luci/cbi.so’
no file ‘/usr/lib/lua/luci/cbi.so’
no file ‘/usr/lib/lua/loadall.so’
no file ‘./luci.so’
no file ‘/usr/lib/lua/luci.so’
stack traceback:
[C]: in function ‘require’
/usr/lib/lua/luci/dispatcher.lua:1329: in function ‘_cbi’
/usr/lib/lua/luci/dispatcher.lua:1018: in function ‘dispatch’
/usr/lib/lua/luci/dispatcher.lua:478: in function </usr/lib/lua/luci/dispatcher.lua:477>
Edit:
I managed to downgrade my openwrt from 19.7.3 to 19.7.2
I am still getting the error.
I have downloaded the file and used manual upload in the opkg page and same error.
When i use the instructions
opkg install http://mudfish.net/releases/openwrt/packages-19.07/mips_24kc/base/mudfish-pi_2.1.25-1_mips_24kc.ipk
i get this
Collected errors:
a little help? Thanks!
Edit 3
I managed to install both base and luci.
However I cannot find IP. there is IP-FULL but im not sure if that’s what it is.
Here is my error now
Failed to execute cbi dispatcher target for entry ‘/admin/services/mudfish-pi’.
The called action terminated with an exception:
/usr/lib/lua/luci/dispatcher.lua:938: module ‘luci.cbi’ not found:
no file ‘./luci.so’
stack traceback:
/usr/lib/lua/luci/dispatcher.lua:938: in function </usr/lib/lua/luci/dispatcher.lua:937>
Ok. So I got it to install on the TPlink AC1750. Openwrt 19.07.2
It works in Full VPN mode. I have a different IP when i check What’s my IP.
Here’s where im at.
PC PUBG works fine when NOT FULL vpn
PS4 Fortnite Does not Work at all… Unless it is full vpn but then I will not be able to play pubg on pc with decent ping.
The PC is connected to the router via Lan Cable
The PS4 is connected through wifi.
Any Help?
Regarding to install mudfish on OpenWRT router, please check Installing Mudfish · MUDFISH link for details.
I found that recently you had uploaded some packet dumps. :slight_smile: I’d leaved my answers there.
