Hello Team,
I recently bought this and it’s current firmware is based on OpenWRT 18.06. Any way for me to install mudfish on this router?
Thank you.
Hello Team,
Thank you.
If you’re familiar with SSH, please try to access the console of the router and show me the output of the following command:
# ubus call system board
OpenWRT 18.06 is old version so the support of Mudfish is a little bit limited. You can find the old version of Mudfish at Index of /releases/openwrt/packages-18.06/ for this OpenWRT version but not sure that there’s a package which working for your router.
Oh! Great, let me try this then. I’ll keep you posted
@weongyo this is what I got
"kernel": "4.14.90",
"hostname": "GL-SFT1200",
"system": "MIPS sf19a28",
"model": "GL-SFT1200",
"board_name": "glinet,gl-sft1200",
"release": {
"distribution": "OpenWrt",
"version": "LEDE",
"revision": "r0-d5ed025",
"codename": "",
"target": "siflower\/sf19a28-fullmask",
"description": "OpenWrt 18.06"
@yeahboo Thank you for this output. When I checked this, it shows the target is siflower/sf19a28-fullmask
. And it seems this target is a custom target of GL.iNet so it doesn’t be supported by OpenWRT 18.06.
It looks it’s hard to support these chipsets. For details, please check the below link too:
