i.ve tried multiple nodes for the game but none seems to be working from the us nodes.
For that case, I need to collect some game packets using Packet Capture with Mudfish.
Hi yes it was the same with full vpn mode
Weird… then could you please confirm whether How to check the basic functionality is working correctly in your environment?
If this works fine but accessing to the game server doesn’t work, it means the game publisher blocks a mudfish node you used… For that case, you need to test with other mudfish nodes.
