Hard to connect after add more credit
Hello
this problem happen after i add more credit
its really hard to connect.
every time i try to connect i got 2 error code and i try connect again and i got 2 error code but different code from before (i’m sorry i forgot the code)
the error is about tap from my network adapter, another one is about restart my router, and another two is about relogin and change node
after i succes login
MUDEC_00446 appear like rain
its about mudfish credit
but i can play my game with this error
but its really annoying my mudfish dashboard full off error notification
and really hard to connect again after i disconnect it
Sorry for this inconvenience. Not sure that it’s still same. If it’s even same, please send us Problem Report. I need to check the internal logs. :frowning:
