have problem with a ping to Seoul. Signal goes trow USA (Atlantic+Pasific), so it’s 250+ms. If there’s another route (for examle, to use server in Kyiv whith the route throw Dubai or like that) it could be less – near 100 ms. Can you help whith that?
No perfect answer for this question because it’s very vary depending on which ISP you’re using or how is the international cable condition good.
Please check FAQ - Nodes document first and test with various combinations.
Plus, it’s fundamentally hard to solve as far away from Kiev to Seoul
You have server in Kyiv and server in Seoul. Make own route (and is there a way to use two servers for full vpn? I couldn’t find the option.)
Also, I’ve used server in Vladivostok (not only me, I see))… So there’s a problem whith heavy load (on yous side). You workind to solve (I mean, should I just wait or go to search another service)?
good bye, mudfish, i think…
Sorry to hear that Mudfish doesn’t help for your case. In my opinion, no way with Mudfish to get 100 ms from your location. ![]()
