Hello. I am using mudfish for Blade and Soul. It was working very well before this wednesday patch. But now i have lag spikes. I was using fast mode with tcp and Leaseweb server. And it was working very well i had below 100 serverdelay in game. Now i have like 200 +delay in game with TCP . I tired UDP now i have better delay but it is going up and down to much, not stable at all. Like 90-160 delays all the way. Dont know whats the problem. It can be cuze of new patch with game ? Or some settings are wrong ?
I have other problem now. I have stable fiber connection. And tested with pingplotter i am getting 109 ping to Mudfish Linode server and 112ping to Digitalocean2 . I am using UDP and fast connection for Blade and Soul. First Blade and soul launcher didnt opened, it gave data error. Like it couldnt connect to internet. Then i got MTU error and changed MTU to 1400 from Mudfish settings and i could get in game. But now my in game delay fluctuating like hell it goes down to 170 server delay(which is very good) and starting to rise up to 500 server delay or more then it goes down to 170 and goes up 500+ again and again.Plus spikes. It is like a Sine Wave. I have kaspersky internet security installed on pc and windows firewall is active. I disabled them and tried but still same. I tried 2-3 different nodes but same. Linode and Digitalocean2. What can be problem ? One more thing I was able to login game before without changeing MTU but i had same ping fluctuating at that time aswell. Can u help me pls ? NOte: Theres no problem with pingzapper and wtfast like this. But i think i can get better results with mudfish as my friends told me. BUt i couldnt make it work.
Yes it could be MTU issue. But I don’t think it’s related with your ping fluctuation (spikes).
Did you check the pingplotter while this issue was happening?
make it work.
However which game server location are you accessing for this game? I thought that you’re playing at Europe, right?
I didnt check with pingplotter when testing ms in game but i checked just before login game and after. And ms value were very stable on pingplotter.I will check like u said and let u know. Its 100/100mbit fiber connection. I am from Dubai, and game servers are on Germany/Frankfurt.
미꾸라지에서 RTT 가 3000 ms 라고 나온다는 것은 현재 사용자님의 컴퓨터와 선택하신 중계 서버간 통신이 제대로 되지 않아 어디선가 패킷 로스가 난다는 것을 뜻합니다.
우선은 중계 서버를 변경하셔서 시도해 보셔도 같은 증상이신지 확인해 보시고 그래도 여전히 문제가 있다면 기본 동작 여부 확인 을 한번 해보시기 바랍니다.
