Hello. I have some problem. Im
Hello. I have some problem. Im plaing in Blade&Soul (EU Windrest). Usually im choosing a server “LeaseWeb” because its have smaller ping (leaseweb - 36ms, next - serverhub - 47ms). But second day if i choose “leaseweb” - ping 3000ms and message from command ping “Reply from 10.254.157.1: Destination host unreachable.”. From tracert “Tracing route to icmp.eu.ncwest.com [206.127.148.132]over a maximum of 30 hops:
 1    <1 ms    <1 ms    <1 ms  10.254.157.1  2  10.254.157.1  reports: Destination host unreachable.” I cant play with ping in 45+ms! What can i do with it? Im using mudfish a very long time and its first problem D: Please, help me.
It looks like leaseweb node is offline
I have the exact same error as you guys.
I also made a post about it but I haven’t heard from him it, we will probably have to wait for him to come back for it to fix, until then we will have to choose less then optimal nodes I guess
Ok, i understand it. But it was some unexpectedly. Thank you for the answer.  Also, i want to ask about servers. Why mudfish dont have servers from Sweden? I mean, it will be very very good, because im living in Russia (St., Petersburg, its northwest), and i have more small ping than on LeaseWeb, 15-20ms vs 36ms.I tested it on another vpn-service. And i think that for people from northwest ping will be better through the Sweden.I used another vpn, but it was not stably, and after that i turned back to mudfish (screenshot with ping from another vpn to bns servers: https://i.gyazo.com/dbeb91ef1099eb9918e8a51de4c9645b.png )
Weird… If you’re referring to DE Europe (Germany - LeaseWeb) nodes, it seems it’s fine now and I’d tested multiple things on this node.  Could you please check it again?
Okay. :-) It’s a time to lease Sweden nodes.  Definitely you’ll see more nodes at there.  Thank you for your feedback.
요금제 에 따라 가격이 다릅니다. ㅠ.ㅠ 요금표 문서도 참고 바랍니다.
To add new game server, I need some game packets to analyze.
To add new game, I need some game packets to analyze.
Hi yes I captured some packets, not sure how much you needed. I uploaded them under "God Slayer MMO packets "
:frowning: Something is wrong because I can’t find your packet dump file at Mudfish side. Sorry for this issue. Could you please send it to me again?
ok I redumped 9mbs of packets under God Slayer packets
:slight_smile: Thank you for sending the packet dump. Based on your packet dump, I had created an item. Could you please equip and test with it? If it is not working properly, please let me know.
Hi Loxch, I tested the item and played God Slayer, the ping seems to be running between 350+ to 250 something; is that what you were expecting?
Please check my answer at other topic. :slight_smile:
