Hello !
I think there is a problem with german nodes, when i use it i got “failed: 60 Operation timed out” with other nodes like FR or UK no problem.
How to solve this ? Yesterday it worked fine
Which mudfish node are you referring to? Is it same after disabling FastConnect mode?
It works when i disable fast connect mode
Please try to pick another mudfish node and test. :-)
Thank you for sending the packet dump. However could you confirm that it’s P2P (Peer To Peer) based game? If it’s, it’s not easy to be supported by Mudfish due to its characteristics. Please check Mudfish for P2P (Peer To Peer) based games section for details.
