Hello there Can you help to i
Hello there
Can you help to install Mudfish on new Openwrt (Lede) ‘LEDE Reboot 17.01.2 r3435-65eec8bd5f’?
I tryed to follow the instructions but it doesn’t work.
root@OpenWrt:~# opkg install http://mudfish.net/releases/openwrt/chaos_calmer/15.05.1/ar71xx/
packages/base/mudfish-pi_2.1.13-5_ar71xx.ipk
Downloading http://mudfish.net/releases/openwrt/chaos_calmer/15.05.1/ar71xx/packages/base/mudfish-pi_2.1.13-5_ar71xx.ipk
Unknown package ‘mudfish-pi’.
Collected errors:
  • pkg_hash_fetch_best_installation_candidate: Packages for mudfish-pi found, but incompatible with the architectures configured
  • opkg_install_cmd: Cannot install package mudfish-pi.
root@OpenWrt:~# cat /etc/openwrt_release
DISTRIB_ID=‘LEDE’
DISTRIB_RELEASE=‘17.01.2’
DISTRIB_REVISION=‘r3435-65eec8bd5f’
DISTRIB_CODENAME=‘reboot’
DISTRIB_TARGET=‘ar71xx/generic’
DISTRIB_ARCH=‘mips_24kc’
DISTRIB_DESCRIPTION=‘LEDE Reboot 17.01.2 r3435-65eec8bd5f’
DISTRIB_TAINTS=‘no-all’
Thanks a lot
It’s a Tp-link MR3420 v1.
Ok thx. I’ll wait anxiously :smiley:
Any updates loxch?
Unforutnately nop. :frowning:
처리해 드렸습니다. :slight_smile: 확인해보시고 문제가 있으시면 언제든지 답글 부탁드립니다.
