Hello there! I'm using Mudfish
Hello there! I’m using Mudfish for Rainbow Six Siege with full VPN mode. I am wondering if I turn off full VPN mode will it affect the way Mudfish handles the traffic for R6 Siege? Is there also a way to be able to surf the internet without using credits while playing Siege(of course while traffic still gets paid only for the item)? Thanks a lot.
If you’re playing with Full VPN mode, yes I think it’s a reason of deduction.
Did you try without Full VPN mode and just with game item equipping?  Is it not working properly for that case?
Umm… Then please send me another packet dump while playing it with Full VPN mode. :-(  Not sure that this issue is P2P (peer to peer) related issue.
Please test it again.  I’d updated the game item for more IP coverage but not sure that it fixes your issue. :-(
Ooops. :-p Is it really working?  Interesting… but good to hear!
> We are connecting through HK nodes but sometimes we experience packet  loss or difficulty connecting but maybe this is more because of Ubisoft  side?
Not sure at this moment.  If this symptom is very repeatable with game item, I think you can test with Full VPN mode again to see that it’s also reproducible with this mode.
음… 프리스타일 2 라면 이미 등록되어 있는 아이템입니다. 혹시 기존 아이템을 장착하신 후 테스트를 해보셨는지요?
I have the same problem in Rainbow Six Siege, it does not work well without Full VPN Mode. Only works well by activating Full VPN Mode.
I need some game packets to analyze because it seems some IP blocks are missed at the game item.
