Help change my Data Plan back to PPT please
I tested the subscription data plan to play PSO2NGS, but I don’t think the speed cap is suitable for this game
While gameplay is smooth once loaded, there’s a lot of loading in this game
It takes so long to load and I get a lot of time out because of the speed cap (although the game does load eventually and there’s no disconnection)
I was going to test the other speed cap vouchers but since the refund is not automated, I think it’s better to just revert back to PPT and try it for a month first to see if it is worth using subscription
I’d left my answer on another topic you created on the Private Support menu. Please check it there. :slight_smile: You can find your topics at https://mudfish.net/forums/iwrote link.
