Help. I don’t want to use Full VPN mode. I’ve tried equipping “What’s My IP” and it shows that it doesn’t work.
- Please check if you have modified registry like Latency Fix /
FastPing or failed to install Mudfish
I think I had modified my registry back then. But the weird thing is, it worked for a short time when I was using Mudfish but now it seems it doesn’t work unless I use Full VPN mode.
Please try to make your own Custom Item
Take a look and find the daemon process what you want to apply
Mudfish in Status → Memory
Then create a Custom Item as input the process name like
P:[name].exe
It’s still not working
Please try to
- Run as administrator
enable Full VPN
mode -
use uppercase
-O
option to change the Mudfish’s working method as
refer
Firewall - Mudfish
Master
Server -
consider to change MAC
Address -
consider reducing
MTU from
1450
I don’t want to use Full VPN mode. I tried all of these and Full VPN mode only works but I don’t want to use that.
Okay… I’m not sure I understand your status problem. Could you please confirm that it works fine with Full VPN mode but not working properly with the game item only?
And could you please explain little bit details what’s not working properly? If it’s related with ‘What’s my IP?’, please try to send me Problem Report.
