Help kakaotalk battleground not working
okay it works full vpn enabled but it is possible to just use vpn for that game? because my credit finish fast if i run multiple websites.
If it works fine with Full VPN mode, it means there’s missing IPs on mudfish game item. :frowning:
Hi i did upload the packet dump and i not sure if its enough for you. can you check it and get back to me? as i tried in full vpn and there is some vpn server does not work with the game… it would says your country service is not available. but some vpn server worked! please make a check thank you
I’d left my answer on the packet dump topic you uploaded at Private Support menu. Please check it there. :slight_smile: You can find your topics at https://mudfish.net/forums/iwrote link.
okay done
