Help: Marvel Rivals Singapore ping issue
I’m having an issue with Mudfish and Marvel Rivals and would appreciate help getting it fixed.
I’m located in Mauritius and play on the Singapore server.
Mudfish Game Item
  • Singapore Mudfish nodes: ~80ms
  • Mudfish RTT graph: ~80ms
  • Marvel Rivals Practice Mode and in-game matches: ~200ms
Full VPN Mode
With Full VPN enabled and connected to a Singapore node:
  • Mudfish RTT graph: ~350ms
ExitLag comparison
I tested the ExitLag trial using Singapore:
  • Marvel Rivals Practice Mode and in-game: ~80ms
I was also using Mudfish around December last year and was getting approximately 80ms in Marvel Rivals without any issues.
Could someone please help me troubleshoot and fix this?
Thanks!
Your Full VPN exception list covers almost all IPv4 addresses, so the game may bypass Mudfish. Clear Setup → Program → Full VPN → Exception routes, save, reconnect, then test with a Singapore node showing ~80 ms (e.g. RansomIT or LightNode 2). If Full VPN reaches ~80 ms but the game item remains ~200 ms, please upload a capture made while playing in Full VPN: Packet Capture.
Ok, thank you so much, i now get ~90 ms ping with Full VPN mode.
Will there be support added for when not in Full VPN mode later down the line?
Glad to hear Full VPN now gives you ~90 ms. This confirms the Singapore route works; the Marvel Rivals item likely misses some current game-server traffic. We can investigate an update, but cannot promise a schedule before analyzing it. Please capture and upload a few minutes of an actual match with Full VPN enabled: Packet Capture. Until then, please keep using Full VPN.
