Help my traffic balance keep declining even though I didn’t use full vpn and not running my only item which is tree of savior.
now it get worse, it even declining while I’m turning off mudfish…
:-) When I checked your access log, such as 111.94.254.77 IP and 111.94.68.65 IP are those which use hugh traffics. And these IPs are Akamai’s edge server (#1 CDN (Content Delivery Network)). So it means you downloaded or streamed huge traffics using these Akamai servers.
I think a reason why Mudfish tried to use these servers for Tree Of Savior was Nexon (game publisher) is one of Akamai’s customer and all Nexon related traffics would be through these servers.
If you’re familiar with Wireshark, I think you can monitor packets to Mudfish specially going to Akamai’s servers.
혹시 해당 증상이 Full VPN 모드 로 하셔도 동일하신 지요?
알겠습니다. 다만 제가 결제 환불을 해드리려고 했는데, PG (Payment Gateway) 사에서 "취소 기간이 지난 거래 건입니다." 메세지가 나옵니다. ㅠ.ㅠ 이럴 경우 제가 계좌 번호로 환불을 해드려야 합니다. 가능하시다면 환불 정책 문서를 참조하셔서 계좌 정보를 알려주시면 제가 처리해 드리겠습니다.
macOS Catalina에서 정상 동작하지 않습니다.
혹시 증상이나 오류 메세지 같은 부분을 좀 더 자세히 말씀해 주실 수 있으신가요? ㅠ.ㅠ
