[Help] options on only using mudfish on certain websites
As Per Title,
i’d like to ask if theres a way to activate mudfish only for select webs
I’ve tried the application, lead me to the ip as web, then clicked “item” tabs, and select item, but theres no selection at all there
Did you try to use Mudfish Browser Extension if you’re connection web sites only? I think it’s more handy to use.
