Hi guys,
Just trying to get AION working with Mudfish. Installed and set up the pathing, but doesn’t seem to be using the node I specified (aka, the ping doesn’t decrease and if I quit the Node the game doesn’t disconnect).
OS: Win 7
I have selected the game “Aion”
Location I have selected “North America”
Node I chose Dallas HostUS 4
When I click Connect and launch the game the ping doesn’t decrease.
@spart@daloze@blaq It seems their game server is moved from NCSoft own network to Amazon AWS… So today I’d updated the game item. When you get a chance, please test it.
No perfect answer for this question because it’s very vary depending on which ISP you’re using or how is the international cable condition good. Please check FAQ - Nodes document first and test with various combinations
I did, my IP always showed in the node I choosed. I tried another VPN just to test out and the other one was working.
I tried to reinstall everything and my ping seems to finally fine now, so I don’t know if you changed anything but it seems better ! (Around 97 to 106)
EDIT : nevermind, it’s super unstable and my ping is going back from 150 to 280 with vpn running.
If mudfish applies to the game properly, then I think your ping will be changed depending on which mudfish node you picked. Did you try to change a mudfish node based on FAQ - Nodes section for your game item? If you’re using the advanced mode, please start with the basic mode.
