hey, how i check which node is the best?
You can pick any node that shows lower RTT avg/stdddev with flat graph
to optimize your connection except the game has been region restricted.
thanks
The advanced mode may cause increases
instability
of connections.
yes, i tried the advanced mode. it wasnt working well
Please check your Connection Protocols when if you get a problem
