Hi admin, It’s me again. :D
My last time use Mudfish is 25-9, on this day i have 26.47 GB traffic data.
And when checking traffic on 30-9, i have 26.44.
Now, 1-10, i have 26.39. With out use mudfish from 25-9. I don’t know what happen? Please explain for me. Below is link to image check traffic status, you can see, my last recent active is 25-9.
Link Image: https://goo.gl/o6uzzx
Thanks you!
Did you check A little Mudfish Credit is charged even if I’m not playing the game! link? If you don’t want to be waste this small traffic, please turn off the mudfish completely.
Please checking for me, from yesterday it’s increase from 26.44 to 26.41. I lost 0.03 traffic without use. @@
Please explain for me if mudfish really need some traffic to sync i will ok with this. :)
P/s: About “without use” i mean i’m not open any client or proxifier and open computer install mudfish too. I know it’s small traffic but i don’t like it automatic decrease like this.
:-) Oh I see. Don’t need to worry about it. I think this issue is caused by currency changes between KRW (Korea Won) and USD (US Dollar) because traffic balance is calculated based on KRW while your currency is USD. If you exchange your currency to KRW, I think your issue is gone.
일단 103.194.165.14 는 일본 게임 서버들중 하나로 확인되어 추가해 놓은 것입니다. 하지만 만약 해당 게임사에서 해당 일본 게임 서버 네트워크 외에 다른 곳에서 일본 게임 서버를 또한 운영한다면 조금 부정확한 상황일 수 있습니다.
wireshark 로 열어서 보긴 했는데 아이피를 어떤식으로 구분해 내는지 궁금해서 여쭤봅니다.
보통 Wireshark 로 구분으로 하고자 하신다면 게임을 진행한다고 가정을 하면, 패킷 덤프를 진행하는 동안 Statistics → Endpoints 에서 활동이 가장 활발한 것이 게임 서버입니다. 혹시 어렵다면 저에게 패킷 덤프를 보내주세요. 제가 알려드리겠습니다.
