Hi, after I installed shadowso
Hi, after I installed shadowsocksr on VPS Plan 1 (IP:14.63.226.163), I
got ssr login info (IP: 59.22.167.217 port: 9900), with which I could
not access the internet. I changed to 14.63.226.163:9900 and it didn’t
work, either. So, how can I fix it? Thanks.
Recently we found that 59.22.167.217 IP is blocked by Great Firewall of China so added a new IP address 14.63.226.163. However if you’d set a new port forwarding rule, please allow at least 5 minutes to be synced with the router configuration.
If it doesn’t work, please try to create new VPS again.
미지원 게임 적용 방법 중 하나를 이용하여 시도해 보시기 바랍니다.
