Hi, FFXIV works using Full VPN mode but when I use Fast connect mode most of the times doesn’t work or take a lot of time to work. Actually, when I use Fast Connect, many times the dashboard doesn’t charge neither. When Fast connect “decides” to work, the game runs a lot better. What can I do? Already did the basic test you mention in FAQ. Thanks.
Are you meaning that you followed How to check the basic functionality with Fast Connect mode enabled? And it worked properly?
