Hi Guys, I have been using mu
Hi Guys,
I have been using mudfish from yesterday to download the Lost Ark client.
I transacted $2.99 and $9.99 just then and the allowance of the plans are circa $15, yet i have only downloaded 9gbs??
The $2.99 plan has an allowance of $18gb and i have only used half and the traffic balance was negative, hence why i transacted another $10.
Is there a way to view the usage details?
It seems Lost Ark blocks Mudfish nodes
Their notice (in
Korean)
You should notice that Lost Ark is pretty large and it’ll consume
doubled if you download it through over a node as Pay-Per-Traffic.
Your computer ↔ node ↔ the game server
About Lost Ark
If you’d like to verify the traffic usages of Mudfish, you should
explicitly enable “Connection Log” which is found under “Setup →
Account → Edit Profile” menu. It’ll log AFTER enabled it
mudfish.net/docs/en/faq/credits.html#how-to-verify-my-traffic-usage
I have used your services for the last 5 days and have been very patient with it… today I am getting an error message as
‘Error: YOur area is not in service’
has mudfish nodes been disabled from lost ark servers?, if so has a remedy being organised?
Probably it won’t working as your expectation. Following tips are
inspired by users’ experiences but it isn’t 100% guaranteed way.
I’m not sure it worked for you but you can try to Full VPN
mode
then make a Korean account
then get
the stove
client
manually at onstove.com/
Closing all web browsers before passing Xigncode would be better
for launch the game.
If you REALLY have will to play the game, you can consider to use
Xiaomi Mi WiFi Nano / Youth
(R1CL)
or Mudfish for ipTIME
router
. You
can put Mudfish program into them, not into PC.
But actually we’re not sure is the Mudfish preinstalled ipTIME shipping
properly to overseas. If you get that Xiaomi Nano R1CL anyhow, you can
install it yourself
A Korean instruction
Bypassing Lost Ark with a Mudfish router is an experimental way and we
can’t guarantee this is always working successfully
Is the mudfish team working on a solution to remedy the problem?
the whole purpose of getting the mudfish was to use the VPN services, for lost ark, if this is not working can i get a refund?
No problem. :slight_smile: I’d refunded it now. Thank you for interesting to Mudfish!
