Hi , I have a problem when I o
Hi , I have a problem when I open my item Discord my ping goes high like 2000-10000 i don’t know why and also some times it goes off automatic can u help me please I can’t use the discord with out the vpn
When I checked your configuration, it seems you’re using FastConnect mode too. Please try to test after turning off it.
