Hi, I need some help here. I'v
Hi, I need some help here. I’ve just subscribed for the vpn service and it appears that if it runs then Blade and Soul crashes at launch just after the XIGNCODE3 check.
I’ve tried different nodes within the vpn web interface, however nothing made any difference. If the vpn is not connected or uninstalled the game runs. Please advise.
Thanks!
After further tweaking on the vpn web interface BNS finally starts up but the game runs considerably slower with the vpn client on. I’ve read a few forum discussions on the above and apparently it’s XIGNCODE3 - which runs at launch - purposefully slows the game down when it detects a vpn connection. Can you confirm this and whether there is a workaround. Obviously if there isn’t one, then I’d like to cancel the vpn subscription.
Please confirm. Thanks.
The advanced mode may cause increases instability of connections.
mudfish.net/docs/en/faq/nodes.html#what-is-the-advantage-of-connecting-to-the-game-through-two-mudfish-nodes-over-one
You can pick any node that shows lower RTT avg/stdddev with flat graph
to optimize your connection except the game has been region restricted.
mudfish.net/docs/en/faq/nodes.html#should-i-use-the-basic-mode-and-set-the-better-node-near-game-server-location
