HI, I need your help so bad. I
HI, I need your help so bad. I want to play in Taiwan League of legends but how to use vpn. I’m from Philippines and Taiwan server blocked my IP and i want to change to Taiwan. But whenever I set it to taiwan server i just can’t press the PLAY button when im on Taiwan node already its very slow it wont let me press it.
take note that the ping is already low the only problem is i can’t click the PLAY button in garena i believe it will work when i pass through it but it seems it won’tlet me
Could you please confirm that it’s also same with Full VPN mode enabled? I’m not sure that there’s an available mudfish node to access the game server though. :frowning:
that sad they blocked everything except hong kong and singapore server
:frowning: Sad to hear that. It means without leasing more mudfish nodes at Taiwan there’s no way to solve…
