Hi I was taxed when I bought the $2.99 plan I was charged $3.25 and I am not based in the US.
Wow thanks alot for the fast reply and refund! Will definitely recommend mudfish to my friends! :D
I’m not sure this is a mudfish node issue or other program issue. Are you encountering this issue whenever you try with simplercloud SG servers?
Please check Merge network profiles for clean up. However it’s known that -I
option mentioned at MUDEC_00045 error link helps to remove this behaviour.
:-) Good to hear that it’s working fine.
정액제로 구매한 아이템만좀 부탁드립니다!
음… 이상하군요. 제가 봤을 때는 게임 서버 IP 가 이미 등록이 되어 있는 것으로 보이는데요… 혹시 어떤 중계 서버로 접속을 시도하셨는지 모르겠습니다만, Full VPN 모드 상태에서는 제대로 접속이 되셨는지요?
예 vpn중에는 접속이 잘되었는데 아이템으로는 접속이 되질 않네요
