Hi, I'm having a strange issue
Hi, I’m having a strange issue where the RTT graphs are showing incorrect and contradictory information.
Configuration and status show about ~43 ms ping
However, the RTT graph on the dashboard shows 64 ping, and indeed if I ping the server through command prompt, it also shows 64…
Did you try to change a mudfish node based on FAQ - Nodes section for your game item? If you’re using the advanced mode, please start with the basic mode. It seems this issue is wrong calculation in the advanced node mode. :frowning:
