Hi! I’m having issues when I turn on the FastConnect option. When I turn off I can log in to the Launcher, but when i put my numeric code and press OK, it doesn’t continue and stay there
I used various servers of Dallas. All do the same Thank you
Ty for answering, i did what u said to me, and “It seems everything works fine. :-)”."
i did it work, but only with Full VPN active and it ruin my test credit so fast, plus i was laggy. I couldnt change for a better node. so
I’d reset your trial credit. I think you can test it again with other nodes.
That was a trial credit.
Is there a free trial version of Mudfish I can use?
Sorry, I read that not too long after sending you the question. Thanks for the fast response.
