hi, i’m using Bolt Home for my provider, i was hoping to get a good result using mudfish for playing dota 2, but i find that i can’t play even if mudfish is enabled, RTT is above 100 all the time, even after i setup jakarta as one of the node, is there any setting that can improve the RTT to be under 100?
Please check your ISP first. When I checked RTT information recorded in Mudfish, it seems RTT stddev values to most of the mudfish nodes are quite unstable. It means your ISP has a network issue. For details please check http://ko.loxch.com/userrtt/?uid=263179 link.
