Hi, I'm using Mudfish for awhi
Hi,
I’m using Mudfish for awhile now. For RainbowSix Siege exclusively.
I live in Middle East, MudFish helps me to get lower ping rates on Singapore servers (Which is still working flawless).
The problem for a couple of weeks is that RainbowSix Siege uses Vivox for in-game communication, which is blocked in Middle East. So, before with the help of MudFish I used to get it work in-game without any problem. But recently with MudFish on, the Vivox stays block because of it I’m not able to use in game communication. Any assistance will be truly appreciated.
P.S. Even changing servers on MudFish before it use to unblock Viviox in-game but now even if I change servers still it doesn’t unblocks it. Please help!
Hello, Sorry for delayed response. Surprisingly it works with full VPN mode. I mean the Vivox and lower in-game ping rate both works. So, I tried to go back to pay per traffic/pay per item Vivox stays blocked in-game. Any solution?
P.S. Like since beginning with pay per traffic my Vivox used to work well but suddenly I don’t know whats wrong!
I think I need to check the packets first.
Ok done! First I tried the file size was 30 mb, I did again 9.75 mb I waited for like 10mins to upload it nothing happened then finally I did 2.5 mb upload. Lemme know if it is sufficient or anything else is needed.
P.S. As a temporary work around can I use full VPN mode? I mean, will it consume balance rapidly?(course for game only).
Yes but it’s Full VPN mode so it could consume more traffics sometimes if you use it wrong.
