Hi, It seems whenever I try to change my MTU under Setup>Programs I get a “Wrong MTU Value” error and it won’t let me change it. Is there anything I can do about this?
Which value did you try to set? It should be less than 1450 bytes.
I was trying 128 and then 256. and tried a few similar steps, none of them would allow me to change
both of 128 and 256 are wrong value for MTU because its minimum is 600 and maximum is 1450 in Mudfish. :-)
:-) No problem. If there’s other questions, please let me know.
After changing my password to only have alphanumeric characters, the problem went away. Maybe it would be a good idea to add an error for people who try to use non-alphanumeric passwords?
Please ignore these messages because its level is INFO. However could you please confirm that How to check the basic functionality works fine after turning off FastConnect mode?
It works but I stay at 10%
Ooops… Sorry for this issue… However can I ask which non-alphanumeric characters you used at your password? I need to check the server code.
I don’t remember the exact characters used (I use a password manager to generate and remember passwords), but it would be one of the characters in the following ranges: https://github.com/keepassx/keepassx/blob/master/src/core/PasswordGenerator.cpp#L151
Basically, any ASCII non-control non-alphanumeric character:
!"#$%&'()*+,-./:;<=>?@[\]^_`{|}~
Please check Auto configuration gets stuck at 10% section first to see where this issue is from.
Okay. Thank you for your feedback. I’ll test and fix it when I get a chance!
Please check Is it possible to use 1 mudfish account on 2 pc at the same time? section for details.
Thank you for sending this problem report. However is there any problem to use Mudfish? If then please elaborate little bit more for me.
I understand nothing … and I do not find … Mudfish does not work anymore for me
Did you read How to check the basic functionality and follow this instruction? Please make sure that FastConnect mode turns off.
