Hi there,
I’m playing blade and soul and it’s using TCP protocol that’s why most players have ping issue since this protocol use 3 way handshaking to the game server, but when I use UDP on mudfish this works fine but there is no big ping reduce, the real-time traffic on the dashboard shows that my ping to the server is very low, but in fact when I connect to the game I still have almost the same amount of ping. my question is should I switch mudfish to TCP, if yes. Is there is any other options I can modify to get the optimal ping for this game ?
There is no special, but please refer to the following article.
If the IP band measured for RTT calculation is different from that of the game
All loophole relay servers periodically check the game server for RTT and send this information to the central server. However, if the target (usually IPv4 address) for this RTT check differs from the way the game checks it, it may be different from the value of the loophole.
Sometimes loopholes may cause problems by incorrectly specifying targets for RTT checks and measuring them to be places other than the actual game server.
If the protocol to measure for RTT calculation is different from that of the game
Basically, Dojo measures RTT using TCP protocol, but sometimes game traffic is based on UDP protocol instead of TCP protocol. (This may cause packet processing priority to change due to QoS equipment). Values may differ from actual values.
Due to the load on the game server
If the RTT calculation in the game is based on the RTT calculation for the game server where the actual game is played, the load on the server may cause a difference.
The RTT graph of Loach is not based on actual game server but because RTT calculation is performed on the network where the game server is located or the network estimated to be nearby.
Due to the impact of the network load on which the game server is located
If the network node where the game server is located is under load due to a lot of traffic, if the Loop RTT is not calculated for that network node, the graph may be different.
Due to the load on the computer itself
Rarely, the computer’s operating system (OS) slows down overall due to the load caused by the computer playing the game, which can cause RTT differences.
로스트아크를 서비스하는 쪽에서 계속 차단 범위를 넓혀가고 있는 것으로 추정하고 있습니다. 우회 접속 차단이 풀리지 않은 상태에서 Full VPN
모드로도 접속이
불가능하다면 로스트아크만
남기고 다른 프로그램을 종료해 보거나 중계 서버 고급
모드로
중계 서버 2개를 이용해 보시기
바랍니다.
