Hi, When I was launching Mudfi
Hi,
When I was launching Mudfish, I came across the error MUDEC_00122 and I’m currently stuck at 10% for the auto-configuration. I tried looking in the FAQ section but could not find out what that error code means, could you please assist in solving this?
Also, whenever I turn run Mudfish, the url file will not trigger correctly and I get an error saying that the file is does not have an association even though it is already associated and works for other .url files.
Please assist in solving these two issues.
Thanks!
MUDEC_00122 is pretty bad because it means mudfish program is crashed. :frowning:
.url files.
Did you set the default browser setting for your Windows? If you’re familiar with regedit, I think you can check it at Mudfish Launcher isn’t working document.
Thanks for the reply, apologies for my tardiness as I haven’t been on Mudfish. It seems to have fixed itself and I believe internet explorer might have been to blame.
Cool! :slight_smile: Please let me know if there are any other problems.
:frowning: Sorry for this inconvenience but at this moment we don’t have a explicit policy to handle this case so you need to create another VPS to solve this.
To add new game server, I need some game packets to analyze.
Not sure if it’s allowed, but I captured some game packets, but the payload was ~64MB and it froze when I tried to upload it. I can’t email it because it’s larger than 25MB, but I’ve uploaded it to dropbox.com and will be emailing support the link. If that’s not acceptable, I can capture more packets that will hopefully be smaller in size.
:slight_smile: Thank you for sending the packet dump. Based on your packet dump, I had updated the game item. Could you please test with it? If it is not working properly, please let me know.
