High consumption again
Once again I come to report another exaggerated consumption of credits, where I cannot know or identify what this is about, even with the WFP mode active, it happened again, could you please check what caused it? There were about 3.89 and now I only have 1.55 from one day to the next.
If this issue even happens with WFP Item mode, it’s not easy to explain. If possible, please consider to use a network monitoring tool like https://www.glasswire.com/ and monitor your traffics per the process.
Thanks, I’ll see what might be causing this and report it here.
