I am facing an issue with a very high credit (kicks) consumption while playing Apex Legends. I noticed that I used 2 GB in just 3 hours, which is abnormal compared to my usual usage.
Could you please check my account/traffic and let me know the normal credit consumption rate per hour for Apex Legends? Also, could you help me figure out why this happened and how to fix it?
Thank you.
Full VPN is off and only Apex Legends is active. There is no fixed normal GB/hour; 2 GB in 3 hours may include CDN/cloud traffic matched by the item. Because Connection Log was off, past destinations cannot be checked.
Enable Account → Edit Profile → Connection Log, reproduce briefly, then review Status → Access Log.
Use Advanced → Network Monitoring to find the process. On Windows/Linux, enable Setup → Traffic → Web Inspect → Item’s Built-In Domains and keep QUIC off.
