HIGH PING FOR 2 MONTH'S
Hello there. So I’m playing from South Korea and connecting my game to the Philippines and this past 2 months I get a high ping 110ms and above which is unplayable. I usually get a 60-80ms but since this May it became 110ms and above. Is there any solution to this? Thanks.
Yeah I’m using the basic nodes Ph cloud sigma 1,2,3,4 have all high ping unlike before they are all 60-80ms only now they are about 110ms and above. I also tried the advance but it’s just the same.
Please try to test your network status from your desktop to 103.56.6.138 (the public IP of PH Asia (Philippines - CloudSigma 3) mudfish node) using How to use WinMTR link.
I think this result shows you where this issue is from. And please try to turn on “Include the result for the advanced mode” option which found under ‘Setup → Nodes’ menu. When it’s enabled, Today’s Pathes will show you the advanced results for route pathes.
