how can I know is starting?
- You can check basic
functionality to make it sure if it’s working.
How do I know if it’s
working?
- Please try to turn off FastConnect mode or change your Connection
Protocol.
FastConnect
mode
will NOT useful in UDP. This feature is for TCP services.
- Please login League of
Legends with
SoftEther then launch Mudfish with Full
VPN
mode
after terminate it or try to change your
node.
Even these workaround
doesn’t work, we no more support to bypass to Destination Server.
